DIY iphone battery replacement
amddude
1,711
My wife's 1G battery is nearly useless nowadays and I was looking to fix it myself. I think I'm comfortable with the installation but is this an acceptable replacement battery type?
Thanks!
pm
Elite Member Mobile Devices
Jan 25, 2000
7,419
22
nevermind. deleted my post. I don't know.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
AFAIK, the battery didn't change design from the first gen to the 3G so I believe it would work fine.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
Actually I lied, it looks like the 3G batteries are a bit smaller than the first gen so it may not fit right. I'm not sure if the connections changed.
lokiju
18,526
The first iphones batter was soldered in.
You'll have to snip or de-solder it and re-solder the new one in.
The 3G and 3Gs are pressure fitted now and do not require this.
