Originally posted by: thecoolnessrune
hink rednecks bother with shooting ranges? A shooting range here is the back yard or a clay pit.
I know we have rednecks and shooting ranges here. Maybe they're a higher class of redneck 😛
Originally posted by: RGN
The bullet is set back? Just toss it.
I kind of doubt putting a live round in the garbage bin is a legal move..
Originally posted by: Flammable
what does a bad round do..?
Originally posted by: MikeyIs4Dcats
your local PD will take the round, as would likely the store you bought it from or a local firing range.
Originally posted by: randalee
2 Pair pliers/vice grips FTW. Pull the bullet. Dump the powder into a house plant. Put empty primed case in cylinder. Discharge safely. Throw away.
Or just do what we all do with a bad round - remove the bullet and take care of it yourself. Part of owning a firearm is knowing how to handle your ammunition. As already stated two pairs of pliers and some tugging and turning and problem solved. The bullet will actually come out pretty easily.
Firing the primer with the empty cartridge is just more safety. It's not a bomb, it's a cartridge.
-edit-
SAFETY WARNING
Don't have the round pointed at you or anybody else as you do this.
Originally posted by: LTC8K6
Throw it in the nearest pond/lake/river if you are worried about taking it apart or throwing it out.
