I just bought a new monitor, the Envision EN-985e, which is on sale for $179.99 after rebate for those that may want a decent monitor, besides this slight problem of course. Hopefully it's not a big deal, but I would like to find out before keeping and recommending this monitor.
The problem is that after I adjust the settings in the OSD, this done while computer and monitor have been running a while, if I shut down for a bit and then turn the monitor back on, the display has shifted about a eighth inch to the right, and once warm again, it will slowly return to my original settings.
Can anyone tell me if their monitors do this, and if it's normal, or do I need to be worried about this leading to further problems. It really is a small problem, but an annoying one for someone who is as anal as myself. I've returned this monitor twice already, and all of them have done this, so it's a thing with these monitors I guess. Do all monitors do this and I never noticed?
Thanks for any light you might shed on this,
John-Paul
John-Paul
