Demon-Xanth
- Feb 15, 2000
- 20,551
- 2
- 81
Originally posted by: Pacfanweb
What are you talking about? Greater displacement ALWAYS means greater weight, assuming you're talking about the engine itself.
Now if you're talking about not meaning the actual car weighs more, then yes.
But in general, you can't get a significant increase in displacement without an increase in the physical size of the engine, therefore it weighs more.
However, usually the weight gain is more than offset by the power gain. Built the same way, a larger engine will always make more power than a smaller one.
No replacement for displacement.
And I don't want to hear anyone saying "but what if you turbo/supercharge the smaller engine.
Well, first of all, I said "built the same way"...which means, apples-to-apples. Forced induction is simply a way of making the engine larger without actually increasing its displacement.
And if you're going to compare a forced-induction small engine to a large one, then the large one needs to be forced-induction, too...and it will make more power. Strictly talking about power potential, larger engines are always better.
To get back on topic, the Euros made smaller cars in general, and used smaller engines as a result.
Here's some fun little tid bits.
A 265 small block and a 400 small block weigh about the same.
The same is true in comparing the 5.7L LS1 to the 7L LS-7.
DOHC heads are massive compared to OHV heads.
It's not uncommon for a DOHC V6 to weigh 400LBs.
Examples:
Acura Legend V6: 491LBs
Renaul 2.8 V6: 375LBs
Toyota Camry V6: 469LBs for the iron block, 401LBs for the aluminum
These are all roughly 3L engines, and weigh comparable to GM's LS* engines that are roughly 6L.
If you compare the weight of a forced induction engine to a N/A, you need to also add in the extra plumbing such as intercoolers that the FI engine needs that the N/A doesn't.
