OP: Based on your experiences so far, I would say the boot time is most likely a BIOS/chipset/driver issue. POST definitely should NOT take 30 seconds (mine takes about 10+).
You look like your AHCI is enabled. That's fine. Your scores are also fine.
I suspect you might actually be CPU limited (I have basically the same CPU/memory capacity/2ndary hard drive as you). I say this from observing task manager and app use during bootup; having both cores pegged at 100% usage is quite a sure sign that there's a CPU limitation going on (esp since you work with 60+ tabs (most probably with some flash), 40 layers (which simply isn't affected by disk speed, but rather CPU/GPU/memory), etc). Too much "crap" at startup, as someone said, is often a cause of this (draining both storage and CPU power). How many processes does task manager show when you get to the desktop from a fresh boot? If this number is close to 100, you definitely have too much going on.
I've said this before and i'll say it again - the SSD is the first device that justifies investing in a quad core (simply because it can handle simultaneous random accesses so efficiently). That said, a SSD does not replace system maintenance - in fact I would say it even encourages it.
 Facebook
Facebook Twitter
Twitter
