I'm not sure what you mean by spectrum, but yea there is more than one full load, that's the problem.
Intel VID is what's screwing people over.
A better overclocking feature would be for the motherboard to determine voltage directly
So you can set a voltage for EVERY load condition and multiplier separately. :sneaky:
Yea, we'd have hundreds of value to test, but that's awesome. 😎
But if you want to be a smartass, try not to confuse physics with math. They aren't interchangeable.
Did you go to one of those special schools where they teach you about voltage in maths class? Oh and if you want to be a smartass try learning to read.
No but we aren't actually discussing the concept of voltage, but the differences in the numbers behind them. That's math. Try again.
I also read just fine, just a simple misunderstanding as to what was being referenced.
I'm not the one being a smart ass, you're the one trying to be and failing at it. Very successful at acting like a douche though. Bravo to you.
Troll battle?
As I recall I won both our previous engagements. 😀
I still don't understand how the VID is determined though. I can't find a graph or chart /table of the VID conditions.
I know it's different for each CPU, but which conditions are there that sets each step.
You read something wrong, I pointed your mistake out, you claimed you didn't make a mistake and started trying to teach me something I already know, I pointed out the exact mistake you made and made a smartass comment because you seem to think you are infallible, you made a smartass comment back because that is your only defence at this point, I made another smartass comment, you tried to twist the arguement to suit your needs......
The upshot of the whole thing is.... you were still wrong, admit it and let it go you are boring me.
P.s Bravo to you too, I will leave you to argue with Boris now he seems to have more spare time than I do.
Umm we have that, it's called speedstep..........
And LLC is a perfect way to make your system unstable. Just because you stress tested doesn't mean you're stable.
Want to make your computer crash? Use something like Linx, and use a tiny problem size (so that it finishes very quickly). Let it run for a while, and your computer will BSOD, guaranteed.
Under shoots are completely uncontrollable with LLC, and eventually you'll dip just below your lowest stable voltage.
Phynaz, you make me so angry. I dislike you very much. 😱
1. Why would you let somebody on the internet make you angry?
2. I don't care in the slightest.
User adjustable LLC is a hack by motherboard makers to counteract a problem which doesn't exist. Somebody decided vdroop was an issue. Intel certainly didn't decide this, because vdroop is actually in their CPU specifications.
Answer: LLC is not needed on a motherboard that meets Intel specifications. You don't even have the means of measuring the need or the implementation.
If you need to use LLC, you have other problems. Period.
LLC has nothing to do with combating V-droop
What in the world are you talking about??? It's what it's there for.
http://www.anandtech.com/show/2404/5
Jeez man, get your stuff strait.
Because there isn't much droop at all in these new chips, and the droop isn't large enough to cause instability.
And therefore there's no need to adjust LLC.
Thank you.
Nah...I'll tell you with LLC enabled I am 100% guaranteed stable at a specific voltage offset and with LLC off I am also 100% guaranteed stable at another offset and it doesn't matter what test you try, it will still remain stable with zero WHEA errors if I have the correct offset set in the bios.
