Disabling Onboard sound
KKiller
Banned
May 4, 2002
177
I have a gigabyte GA-7VRXP, and have checked off the option to "disable" on board sound chip in the CMOS. However, windows still insists on detecting the on-board chip. Since I have a Hercules sound card attached, both these hardwares conflict, and I can get no sound out of my computer.
Do any of you have a solution to this problem? My guess is that I haven't fully disabled the on-board chip and that I need to do something in addition to what I am already doing.
Wingznut
16,968
Check the manual and see if there's a jumper to disable the onboard sound.
Have you removed the onboard sound drivers and applications?
KKiller
Banned
May 4, 2002
177
That did it! You're BRILLIANT GUYS!!!!!!!!
Disabled gameport/serial port and boom it worked!
