directx problems, need help please
Buliwyf
41
under network under DXDIAG it shows errors for directplay and tcpip and ipx .. i dont know what happened. I have directx 9 installed and i cant install it again because when i run the webupdate for directx it says "directx did not load a required file" I have no idea why it is doing this.....
can someone please help?
flippo
474
Have you tried to uninstall directx and reinstall again ?
The site which you can download uninstall program for directx 9.0: Here
Buliwyf
41
yep, didn thelp. i just reformattd my pc, now games that require directplay work fine. dont know what happened.
flippo
474
Well.. you know with Windows the only way to solve the problems is clean install OS :)
