Originally posted by: Jnetty99
I have a Triple LNB with 4 outputs but it was only setup for three outputs for three rooms.
check picture here pic
When the installer put this, it took a while, they replaced the old dish and added the new lines etc etc. Then he must have spent like half hour adjusting the signal, it looked complicated and he had all his cool tools.
Installing the dish is the tough part (although you can DIY that, too, but with most places offering free installation, there's not much point).
If that's one of the newer dishes, which it sounds like, i believe the mux is already built right in with the four outputs. If you only want one TiVo unit and you've only got 3 rooms set up, there is probably another output somewhere that you just have to extend to whichever room you want to have two outputs. If you can find that extra output cable, you're golden.
