anyone use these... either the two fan or tripple fan ones... how do they compare in noise to other's you've used (specifically the antec trupowers if anyone happens to have both 🙂).
I have a 420 watt one with dual fans. It is relatively quiet, quality construction, and the voltage readings are right on. I would consider them one of the best bang/buck power supplies out there.
TTGI power supplies are top notch. they are right up there with other quality PSU's like antec and sparkle. you won't be dissapointed by TTGI's quality or noise level, they are some of the quietest cheap power supplies.
