Farmer
- Dec 23, 2003
- 3,334
- 2
- 81
I'm going to give you the best advice a pro photographer can give another aspiring photographer: Get Cheap. Get Cheap lenses.
Are you kidding me? The difference between a kit lens and a real lens is obvious from anyone who takes more than a passing glance at your photos. It's not the 80s anymore. the image processors on modern DSLRs do 90% of the darkroom. For a photographer on a budget, Photoshop should not be a problem, if you get my meaning.
You don't need to spend $2000 on glass. You also don't need to use kit lens. There is plenty of good glass on the order of hundreds of dollars.
Fast AF is another attribute of expensive lens, but you can't say quality of optics doesn't matter.
Paladin3:
I can understand where you're coming from if you're a news photographer, but there certainly are applications where speed is not the most important thing.
