Originally posted by: Rubycon
Originally posted by: daw123
Rubycon, does a PC shutdown immediately when you press the case power button, or does it go through the Windows shutdown process. I'm not sure because I've never tried. If the latter is the case, is there a way of stopping the Windows shutdown process, so that the PC shutdowns immediately.
With regard to your idea, how would I go about doing this (specifics please for a layman).
I figure that I can use the signal (essentially a switch which is usually on) from the TBalancer Extension Set, since this signal is what would be controlling the shutdown function via the case power switch if there were a problem and if it was connected as M Cubed intended.
When you ground ATXPWR on the mainboard Windows will initiate a shutdown. A hung program can stop it and if the system is hard locked it won't respond. HOWEVER if you hold that ground the system will shut down regardless of what Windows does OR if it's hard locked. At the very least you'd want it that way.
Disengaging mains power (breaking both legs hot/neutral if you're in the 'States running on 120VAC or both hots in the case of 240VAC) provides the most fail safe method to completely remove power. Electrically it's the same as you yanking the power cord from the machine but leaving the ground line intact. (A triple pole relay can be used if you desire to break the ground also but that is completely optional and MAY violate regulations depending on your local codes, etc.)
Solid state relays can be normally open or normally closed. In this case you want normally open - that is if the turn on voltage ceases to exist at the terminals the connection is broken. This is also known as fail open condition. Your monitoring circuit supplies the necessary turn on power - usually 3 to 20+ Volts either AC or DC depending on the relay type. When this power is removed the relay terminals will open. This is a solid state relay so it has no coil/armature/contacts, for example.
Finally I'd recommend a time delay with this circuit. Basically it warns you that flow has dropped/ceased and will give you time perhaps a minute (but not too long as parts heat up and if you restart the pump with hot parts the shock is not good, etc.) to correct the deficiency. This way the system is not plunged into darkness instantly without warning!
