- Aug 30, 2008
- 2,593
- 0
- 0
Hello guys and girls,
I'm looking to buy early next week a digital flow meter for use with the M Cubed BigNG controller. I have the following two choices:
M Cubed T-Flow. Cost: £18.50
Alphacool 17206 Stream Control SC1 Optimised for Highflow with built in sensor. Cost: £13.70
What puts me off with the M Cubed T-Flow is that the inlet and outlet are on the same side, which will be awkward to retrofit in my existing loop.
I prefer the Alphacool meter because it has a "straight through" flow configuration. The problem with the Alphacool is that it uses a stainless steel spindel on the impeller. I'm not sure if this will cause problems with my all brass/copper loop. (btw do the Swiftech pumps use stainless steel spindels?).
Do you think this will be ok, or are my concerns justified?
Edited for spelling for the pedantic (such as myself) among you
