difference in zalman coolers
mindwreck
1,585
ZM80C: $27@svc
326G 1200cm dissp. area
ZM80A: $25@svc
400g 1300cm dissp. area
both use copper tubes
Which ones better?
McArra
3,295
Originally posted by: Nebor
The C version has mounts for the OP-1 92mm Zalman fan.
Yep, that's the greatest difference. With that fan performance increase is huge.
InlineFive
9,599
Another vote for the C-Version. It works well on my Radeon 9600 Pro @ 465/310 even with only about 30CFM of system airflow. I bought it instead of the A because it has less mass.
-Por
nvfx
Banned
Apr 6, 2004
199
The Zalman HP-80A is the older version but looks very very Sexy because of its Golden Color.
The ZM-80C has a fan bracket so if your are buying this Cooler for OC, make sure you buy a ZM-OP1 Fan as well for 10 $.
Thats a total of 40 $ almost but its a beast that cool hell.
OR MAY BE YOU WANT TO BUY A THERMALTAKE GIANT III, if you are unaware.
TT has released thier Giant III which has DUAL HEATPIPES + a normal Fan + A sense less Blower Fan + Great manuals.
The TT Uses Nickel Plated copper heat pipe while the zalman uses a Gold plated Nickel Tube.
I think a Zalman ZM-80C With fans is superb + Silent But the TT Giant III Takes full points for Ultra Cooling, i havent seen the difference b/w TT and Zalman though...
EarthwormJim
3,239
Just so you know, you can use almost any fan with the ZM-80C. All you need to hold it on are small enough headed screws and some kind of bolt to fasten it to the fan.
ChronoReverse
2,562
31
Yep, I put a papst 6800rpm fan (on a fan controller though) on mine instead of buying the zalman fan. The difference with the fan on low and the fan off is like night and day.
McArra
3,295
I also like Giant III better ( I have one cooling my 9800pro at silent mode and it's just great).
