Difference btwn a 94' Trans Am and a 94' Firebird Formula
WHSLacrossekid
6,330
They're both the same color. Both have T-Tops. Both have a 5.7L
What's the difference? I've only looked at the Trans am so far which is $5970 (has 112k miles) and the Firebird is $5500 (has 91k miles)
Mutilator
3,513
10
I think the Formula is slightly lighter and faster... not sure what it's missing that the Trans Am has though. I didn't really research Firebirds too much when I went car shopping a couple years ago... mainly because too many people had them. ;)
If those are your options, I'd get the Formula.
cheapgoose
3,877
Originally posted by: nater
Originally posted by: notfred
The trans am has a bigger spoiler.
AKA it has 2000 more hp. Go for that
ok, we all know the spoiler hits its limit at about 400 more hp. unless you get one of those pink one with lots of honda stickers on it.
DougK62
8,035
A Trans Am is a Formula that has pretty round effects and such - looks nicer. A Formula just looks like the base model except it has a V8. May be other small differences too.
Demon-Xanth
20,551
The T/A is a higher trim level. It usually comes with more options and the ground effects package is a bit different.
UNCjigga
25,577
10,265
Didn't the Trans Am offer a ram-air option, while the Formula did not? Trans Am does look a bit different...
Vette73
21,503
9
Originally posted by: shuttleteam
The Forumla has a stiffer suspension, only offered on the TransAM GTA.
-DAK-
94 is the NEWWER body style, no GTA here.
But for the most part the T/A is a fancy and nicer looking car, the forumla is a very fast balls to the walls cheap car. If you want all out speed go formula, if you want looks and some speed then go T/A
Dulanic
9,968
592
Ok main differences...
Raised Spoiler on TA
Front Nose
Formula is lighter
Rear Bumper
Fog Lights
Ground Effects/Side Skirts (TA has em, Forumla doesnt)
Some people say the gears are different... but both Forumlas and TA's had the same gear options.
And TAs typically had more standard options, but both could get the same options.
I have a 94 Formula myself.
