Dieting Question - How do pickles have 0 calories?
DWW
2,030
Originally posted by: Eli
Originally posted by: DWW
Originally posted by: DurocShark
Originally posted by: episodic
Atkin's Kosher Dills in the Large Gallon jars. Got it from Wal-Mart for 4.00$- says on the side 0 calories.
That's unpossible. Pickles=fruit. Fruit=carbs.
I think the company is full of pickles!
Actually pickles aren't fruit ;)
Edit: Well to be PC I realized I shouldn't say the above statement. Some pickles stray :D But they are generally vegetables :p
Cucumbers are a fruit; they contain seeds.
Pickles are pickled cucumbers.
Therefor, pickles are pickled fruit.
:p
So anything containing seeds would be a fruit? Pumpkin is fruit?
Edit: nm looks like pumpkin is a fruit. Wow never knew that pumpkin or cucumber are fruits :)
rezinn
2,418
Sounds like they just truncated the 1/5th of a pickle being 0.7 calories to it being 0. That's probably not a "correct" thing to do. And calories are only measured if they are available for metabolic use. We don't burn H2O for energy, we burn carbohydrates, fat, alcohol, proteins, etc.
Eli
Super Moderator | Elite Member
8
Yes, by definition.
A vegetable doesen't contain seeds, like a carrot or beet.
Although we often mix them all up, since most people consider fruit to be sweet, and vegetables not..
Jzero
18,834
Different people classify things different ways.
A botanist will tell you it's a fruit since it bears seeds.
A horticulturist might tell you it's a vegetable since it is a vegetable plant based on its characteristics.
A chef will classify it depending on it's use. In a soup, a cucumber (or tomato for that matter) it would be considered a vegetable. In a salad or dessert, a fruit.
myusername
5,046
The vlasic pickle that I just ate had approximately 10 calories, according to the nutrition label (5 calories per approximately half pickle). I don't mind; they taste better than the other brands.
Eli
8
Originally posted by: notfred
The way they measure calories confuses me. It seems to be an inexact science, at the very least.
Shouldn't hot water contain calories?
A calorie is the amount of energy required to heat 1ml of water 1 degree C, right? From what starting temperature?
Shouldn't hot water contain some calories then?
How do they measure the energy in foods, burn them and see how hot water nearby gets? How much of that energy comes from the air and not the food?
What about food that goes through you? Do calorie counts take into account the fact that a good portion of your food comes out the other end without being absorbed by your body?
That's actually a pretty good question.
Obviously, they only measure calories that you can metabolize. But I'm not exactly sure what methods they use to get the calorie figure on foods..
FoBoT
63,084
15
fobot.com
Yes, by definition.
so what is corn? the little kernels are seeds, so an ear of corn is a fruit? :confused: :Q
Eli
8
Yes, by definition.
I was actually pondering the same thing when I posted that, because at first I said carrot or corn. :p
But yes, technically a corn is a fruit. An ear of corn contains hundreds(or whatever) of little fruits.
Murphy Durphy
1,248
I don't know about you guys, but I'm starting to get the word 'pickel' stuck in my head. It's such a odd and unique word to pronounce. ... pickel. Pickel. Pickel. PICKEL. Ahhhhhhhhhhhhhh...
pickel.
Vic
50,422
14,337
Nope. Corn is a grain. The edible seeds of a grass. Same with wheat, rice, barley, etc.
Fruits are when you eat the seed-bearing ovaries of a flowering plant. Tomatoes, apples, cucumbers, pumpkins, etc.
Vegetables are when you eat the root, stalk, or leaf of a plant. Potatoes, lettuce, cabbage, carrots, etc.
edit: and there is no fscking way that pickles have 0 calories.
Pex
Banned
Aug 21, 2003
1,161
celery has negative calories because of the energy it takes to eat them.
Eli
8
Well.. if you want to get technical, wheat, rice and barley seeds are fruits too.
A corn(and wheat, rice..) is a type of fruit called a caryopsis. The seed is the fruit of the corn(wheat, rice..) plant.
You are correct that they're called grains, though. They're a type of fruit called a grain. That's what a grain is. The fruit of a cereal-grass. :)
badmouse
2,862
"sweet" pickles have more calories than "sour" pickles.
There's not much to a cuke except water and a little bit of structure (cellulose?).
conjur
58,686
Uh...aren't pickles from cucumbers?
Cucumbers == vegetables
TitanDiddly
Guest
Dec 8, 2003
12,696
Below a certain count of calories, the FDA lets the manufacturer say zero. Sweet and low for example has a big sticker saying 'ZERO CALORIES!" but it actually has 4. It should be marked on the packaging.
gopunk
29,239
not sure if anybody has responded, but you're confusing several issues. "calorie" as it pertains to food has to do with how much energy it gives you, i.e., how much energy your body can burn as a result of digesting that food. the whole heating up water thing is for purposes of measurement only.
jagec
24,442
why is it inexact? You can't BURN water. The calorie (kilocalorie, actually) in food is measured by burning the food in question and, as you say, seeing how much heat is released. It's basically the sum of the enthalpies of combustion * the quantity of each combustible chemical in the food. That's why sugary stuff is so high in Calories. The starting temperature doesn't matter (except to the extend that it changes the specific heat).
Eli
8
Didn't read the thread, didja? ;)
Once again, cucumbers are fruit.
StageLeft
70,150
They do, just very little. You can eat tons of them, but the problem is sodium - gotta watch out for it. Pickles are nice!
Eli
8
That's sig material......
:D
spidey07
65,469
IIRC they burn the food in a special container and measure the energy.
No - water has no calories...it doesn't burn.
yep, burn them...knew there was a device called a calorimeter.
http://www.straightdope.com/classics/a3_097a.html
conjur
58,686
Everyone calls them vegetables except maybe the most anal of horticulturists. ;)
