It's a 13 gallon tank. So with 1.3 gallons, if she had filled it up, it would be a 9:1 ratio of gasoline: diesel. That is very significant. It would definately change the properties of the gasoline... most likely in undesirable ways. Filling the tank up would probably actually be the worst thing(well.. other than trying to run it on straight diesel), because it would stretch the exposure time way out.Originally posted by: PlatinumGold
sheesh. some of you guys take yourselves way to seriously.
how many of you posting really know for a fact?? or are most of you just guessing??
i don't know for a fact. but i do know this, if there is a large enough amount of gas vs diesel in the tank, the engine will be fine. what that ratio is, i don't know, but i do know that at some point it will work without any real issues.
all this discussion of how diesel is combusted etc only serve as theory and don't really deal with the reality of the situation.
she has 1.3 gallons of diesel, is 8.7 gallons of gas going to be enough?
if he syphons, no matter how well he syphons off the diesel, SOME of it will remain in the tank, let's say .3 gallons, if so, will 9.7 gallons of gas be enough?
less is better, so i wouldn't take a chance. i'd syphon, but who knows, mb 8.7 gallons of gas WILL be enough, plus they can burn about 3 gallons of it and add more gas further reducing the concentration of the diesel. etc.![]()
Think of it this way.. When you mix oil with gasoline for a 2-cycle engine, a typical ratio would be 40:1. That would only be 40oz(0.31gallons of diesel) in 12.7 gallons of gasoline.
Originally posted by: JulesMaximus
It will damage the engine. I did this once many many years ago and had to have the car towed to the dealership for about $500 worth of repairs.
what was your ratio of diesel to gas. this is a very important point. there is a point at which there would be MINIMAL damage.
Originally posted by: Skoorb
So what did she end up doing?
Originally posted by: alkemyst
people's perceived knowledge of cars on this board is extremely painful.
I would love to go add 1.3 gallons of diesel to my 10.5 gallon tank, however, even if I did and as expected nothing terribly bad happened....90% would still doubt, I'd be willing to bet more than a handful would claim the station accidentally put regular gas in the diesel tank and I got lucky.
Oregon has that same law and all everyone does is bitch about it.Originally posted by: Linux23
that is why every state should adopt the NJ State Law of never letting customers fill their own tank.
this is one time I can say that I am proud to be from Joisee.
Go add diesel to your car then and STFU.
Diesel is fine for a gas engine. I often fill the maxima up with diesel if prices are good. My miles per gallon go to about 35/48, although I do lose some overall power. My low-end torque is sweet though. Nissans are so sweet because the engines will take any gas you put in it. You can even put orange juice in and it will use the energy in that to run. It's an expensive way to run it, but you get a huge horsepower boost running orange juice. Unfortunately you want a pulp free one, otherwise the fuel filter gets clogged fairly quickly.
Do you use stickers too? Did you know teh sticker give j00 5 HP each.
Clearly more than momentary. She's dating you, isn't she?Originally posted by: dtyn
She had a momentary lapse of intelligence apparently.
N/A Diesel iz teh Sux0rOriginally posted by: Skoorb
Take off the air filter on your truck and see what kind of animals end up in your Lysholm.Originally posted by: LAUST
She had a momentary lapse of intelligence apparently.![]()
Dem are fightin werds, boy. Don't be messin with no Tennessee boy, less you want a good ass woopin.
EDIT: And not only is she dating me, but she's marrying me too. Guess she's really stupid!
prolly take out my MAF before they do the blowerOriginally posted by: Howard
Diesel is fine for a gas engine. I often fill the maxima up with diesel if prices are good. My miles per gallon go to about 35/48, although I do lose some overall power. My low-end torque is sweet though. Nissans are so sweet because the engines will take any gas you put in it. You can even put orange juice in and it will use the energy in that to run. It's an expensive way to run it, but you get a huge horsepower boost running orange juice. Unfortunately you want a pulp free one, otherwise the fuel filter gets clogged fairly quickly.![]()
You don't mix normal motor oil with gasoline for a 2-cycle engine, it is MUCH lighter.. probably even lighter than diesel fuel.Originally posted by: PlatinumGold
mb this is my ignorance speaking but i've always believed diesel to be significantly lighter than motor oil.
if diesel is 1/2 the density of motor oil, than the 9:1 ratio you mentioned would be equivalent to a 18:1 ratio with motor oil.
otoh, people drive cars that leak and burn oil for long periods of time. could the diesel be any worse than that?
I agree, people's perceived knowledge of cars on this board is extremely painful.Originally posted by: alkemyst
A 2-cycle engine with a 40:1 mix ratio can produce a fair ammount of smoke. Like I said, 8 - 12:1 would be VERY significant. It would screw with the injectors, ECU, and after a full tank could produce some fouled plugs, possibly kill your catalytic converter...
The difference between a car that burns oil and putting heavy fuel into the tank is that the fuel from the tank has to be metered into the cylinders. When an engine burns oil, it is due to worn cylinder/rings or valve bushings, so it slips into the combustion chamber by "accident" and independantly of any metering systems.I agree, people's perceived knowledge of cars on this board is extremely painful.Originally posted by: alkemyst
I would love to go add 1.3 gallons of diesel to my 10.5 gallon tank, however, even if I did and as expected nothing terribly bad happened....90% would still doubt, I'd be willing to bet more than a handful would claim the station accidentally put regular gas in the diesel tank and I got lucky.![]()
You go mix diesel with your gasoline at ratios of 10 - 12:1 and come back and tell us what happens. It IS going to create some symptoms and problems. Of course it isn't going to cause your engine to grenade or something, but it isn't going to like it, I can tell you that much. I bet your car doubles as a mosquito fogger.
Some newer 2-cycle engines use ratios of 50:1, 80:1 and even 100:1.
I mix oil at 25:1 to break a 2-cycle engine in, and it smokes like hell on that rich a ratio. 12:1 would be insane.
How old are you? You look too young to be getting married.
