DIABLO 2 HELP?
misterdante
it won't even go beyond the auto-play splash screen .. where its says to play diablo .. click on play and it flashes a couple of times then .. goes back to windows ... any suggestions ??
o ya reinstalled a few times .. in both single/multi and full .. plus tried the 1.01 patch .. same situation ..
Windows 2000 professional
amd athlon 550
epox 7kxa
256m nec pc100
cl geforce ddr 5.30 drivers
sb awe64
promise fasttrak100
2 ibm gxp75 15gig raid0
memorex 48x ide cdrom
Gatsby
1,588
try changing the video settings from direct3d to directdraw.. you won't get the nice lighting effects but it'llrun faster.
Gatsby
Caitiff
677
Only other thing I've seen is the video drivers, or the installation of Direct X. Trying doing a search on your hdd for a prog called 'dxdiag.exe', run it, and see if the direct draw and the directplay work ok there. I always start there.
