nonnormman
I'm using a router for dhcp, but I want my dhcp server to assign a specific scope of ip address'. The router assigns 192.168.1.2-192.168.1.50 and I want the dhcp server to assign the range 192.168.1.53-192.168.1.80.
You almost certainly don't want this. You should only be running one DHCP server on a given broadcast segment, otherwise things get complicated. What are you trying to accomplish by splitting the DHCP service across machines? Why can't one machine do the work? There are conceivable situations where you might want more than one DHCP server on a segment, but they're rather unusual and it's not clear why you would want to do this.Originally posted by: nonnormman
Enough bumping already. Nothinman and I (and probably others) are clearly following this thread and trying to help you. This forum doesn't move that quickly, and we're not at your beck and call, so be patient.Originally posted by: nonnormman
bump
bump
I'm sure you would be making much more progress if you answer the question both Nothinman and I have already asked: Why do you want two DHCP servers on the same segment? It's highly likely that there's a much simpler method of accomplishing whatever it is you're trying to do, if you would tell us what that is.
If you're set on figuring things out yourself, that's fine. But why create a thread in the first place if you're not going to respond to what people are asking you?
All I'm trying to do is to get a linux dhcp server up and running for the experience. It doesn't matter whether it's the only dhcp server on the segment or not, I just want it to work.
I still can't figure out why this thing won't start. When I check the syslog, all I see is local host repeated several times.
Paste the syslog entries here. You could also try starting it with the -d flag (i.e. /usr/sbin/dhcpd3 -d eth1) and see what it says.
Yes it does matter, if you have 2 on the same segment at best you'll have a 50/50 chance of either working properly.
