Deus Ex 2: Invisible War Previews!(Updated)
Mem
21,476
13
Xbox preview version here@Gamespot .
The visuals are beefier across the board on the PC, depending on your hardware, and the frame rate is a bit more solid. The Xbox doesn't come in too far behind--although the frame rate isn't as smooth as it could be, it appears to perform at about the same level as in Star Wars: Knights of the Old Republic, and it keeps the action playable.
Mem
21,476
13
Preview@Telefragged ,
Throughout the game there are quite a few side quests you can do - some of them are official quests than an NPC may give you, and many of them have some pretty decent rewards as well. Other side "quests" may just stem from a door that is locked, or an enemy you otherwise would avoid.
BoomAM
4,546
LOL.
Just DLing it now off FilePlanet.
If it runs well at the setting that i want in it, then i`ll import it. If not, then i`ll wait till i upgrade to buy it.
