Mazhar_Uchiha
Hey Guys,
I am buying a Dell Optiplex 740(used) mini tower with AMD Athlon X2 5000+, the main reason is that I want to play the latest games.Thats why I am thinking of buying a HD 5770 or a GTS 450.
Well basically I need to know is, would the HD 5770 or GTS 450(full size) fit in the system? Also can u tell me would the system support pci express 2.1 or 3.0 cards? I know that they are backward compatible but Im asking because Ive already had a very bad experience with a HD 5550.I bought it thinking that it would be backward compatible but it didnt work(I had a lenovo i945 system with Pentium D) ,although theorotically it should work.It didnt work even when I upgraded the BIOS.
So these are the two problems Im stuck with. Please can someone help?
Thanks in Advance 🙂
Edit:
Processor: AMD Athlon X2 5000+
Ram: 2 GB DDR2
Power Supply : 450 watt
Thanks in Advance 🙂
Edit:
Ram: 2 GB DDR2
