- Jun 13, 2003
- 410
- 0
- 0
The same LED cycle occurs. I've also found that it charges with my docking station but not from the outlet.
Found someone with the same problem, but cant see the solution:
http://www.experts-exchange.com/Hardware/Laptops_Notebooks/Q_21646461.html
My Dell Inspiron 8100 battery light has been blinking orange. I pushed the test button on the battery and it blinks 3 times with 3 test lights coming on (every other one config.), then the 4th blink all 5 test lights come on, then it stops blinking. I'm guessing this means the battery is bad? How can I test the laptop to see if it really is charging the battery. I replaced the battery with a referb. battery and it showed green light for charging but will not run on battery and tells me my battery is low. The referb. battery test button brings on all 5 test lights.
