Dell Inspiron 660 3-4 monitors?
Thanks guys!
Choice 1: I have come to the conclusion that this will not work....
Choice 2a: Yep, my monitors have display ports and I have a displayport to HDMI right now....checking to see if I can find a used card!
Choice 2b: Looking into it
Choice 2c: Probably not the best bet
Thanks so much for your help!
2a: remember, if that displayport->HDMI is passive, it won't work (you can still make it work by using a displayport<->displayport cable)
2b: your current monitors are all displayport capable... i wouldn't go route 2B unless I want to use some legacy (aka HDMI/DVI/VGA) monitors in the future... I would say futures monitors that you buy would have displayport as well
just a hint, you can get something that drives 6 monitors if you want to:
http://www.newegg.com/Product/Produc...82E16814129274 - $250 single slot (might want to upgrade the PSU to a 430W as well)
