Originally posted by: Callaway
Also comes with a valid licensed operating system.
Originally posted by: Lurker1
To Supafly specifically, if I cared to copy the Dell exactly, your numbers are correct. However, to get the OC capability that the 6300 is already legendary for, you're looking at a $170 or more motherboard. Memory is the same issue, you'll need better than bottom end RAM. And then, why buy a $50 80GB drive, when you can get a $70 300GB drive AR (mine's sitting on the shelf waiting for my new system😉. Also, power supplies that can handle the Core 2 with a decent graphics card is going to run you a minimum of $60, unless you can get a killer deal ($22 AR and taxes).
I also like my peripherals to actually work reliably, which is why I use Plextor DVD burners almost exclusively. I just haven't had good luck with other brands, although I never got around to getting one of the NEC's. That will set you back about $50-80, depending upon rebates, for a decent burner. But still, with everything said, you can buy just a notch above the Dell in price and get $1K or more additional performance out of the machine.
That's what I call a hot deal. I'm not interested in beating Dell's price in an apples to apples comparison, unless it's a delicious perfectly ripened apple to Dell's worm-infested mealy apple.
Originally posted by: Hulk
This is definitely a decent deal if not quite hot.
But in a month or so I bet we'll be able to get this system for less than $500, probably with a faster CPU, maybe even more RAM and a larger hard drive.
Then it will be HOT!
Originally posted by: supafly
E6300 $190.50 shipped.
512MB $50 shipped
Mobo $86.12 shipped after rebate
power supply $50 shipped
80GB hdd $50 shipped
DVD-rom $15
7300le $42 shipped after rebate
XP home $90 shipped
Case $30+ depending on what you want
Total comes to $603.62 before monitor depending on the case.
Cheapest 19" LCD on new egg is $190 shipped.
Total with monitor comes to $793.61
Assuming you know what you're doing and you have the free time and nothing needs to be RMA'd and you can wait for rebates, you'll save $5.39 by building your own. Yippie.
Of course, there are other benefits to building yourself, but if you just look at it for the price and convience factors, might as well get the Dell.
edit: to Bamacre: About the PSU, it's not enough to drive even a base X1900XT or 7900GT configuration @ only 375W. Minimum recommended is 480W for those cards, with a min 30A on the 12V rail. There's even discussion that the Antec 500W Smartpower isn't strong enough to drive such a system reliably since it may not provide enough RMS (average) power.
Originally posted by: Underclocked
SATA burner, look on the Dell site in accessories. There are two or three. The one that came in the 9200 I worked on is TSST (Toshiba/Samsung) and the additional combo drive was a Sony. SATA drives
Or just buy a PCI host card.
Originally posted by: niji1875
Dell 92001.86Ghz 512MB/80GB Serial ATA, DVD, 7.1 Audio, Geforce 7300LE Video, Dell LCD, 1yr warranty, XP Home. Free shipping.
<a target=_blank class=ftalternatingbar...s=04&kc=6W300&l=en&oc=3d92h5&s=bsd</a>">Dell 9200</a>1.86Ghz 512MB/80GB Serial ATA, DVD, 7.1 Audio, Geforce 7300LE Video, Dell LCD, 1yr warranty, XP Home. Free shipping.
Are there any long time dell people that were converted to Dell who used to be home builders who figured out that that the time and energy going into home builds wasn't worth it but now feel that the core 2 duo is the first chip since the early 300A to 450 overclockable celerons that is worth actually abandoning Dell because running a core 2 duo at clock speed would be like driving a ferrari F50 at the speed limit and are actually excited about CPUs for the first time in years because the Core 2 can actually save significant time in video editing among other things?
Originally posted by: bamacre
I don't see how the "313-4662" wouldn't work in a Dim 9200 if it fits fine in the E520 and E521 systems.
