hi ,i have laptop inspiron dell 1420 display lcd but 1400 mobo without graphics nvidea.., my display started as single vertical lines and little flickering horizontal lines but later it increased and one day the display got blanked, with external monitor the display is fine and good.
i switched off the lights and in dark room when i turned my laptop on,i see dim light start ...then after sometime after post i guess i get to see the box on the screen inside which vertical lines are present ,when i switch the room lights on ,i cant see those vertical lines ,its not visible..the display looks blank so i can understand the bulb in lcd display is worn out and anything else about inverter etc..i will be glad to know if i could diy mine,thanks
