delete
qbackin
Banned
Dec 26, 2004
1,900
It keeps saying found pci ide controller but I dont have one????????????????WTF
And found ide channel
And my cd-rom dissapears
says found hardware over and over again
cornholio2
172
The first thing I did was read the manual and read it like five times before building my rig and ran fine.
Promethply
1,741
That can sometimes happen when you install the OS on a PATA drive, later connect an SATA drive, and then reboot into your PATA boot drive.
If that's the case, then you just have to disconnect any PATA drive, and reinstall the OS on your SATA drive. Then after successfully installing the OS on your SATA drive, you can reconnect the PATA drive onto the motherboard, and you won't encounter the above stated problem :)
qbackin
Banned
Dec 26, 2004
1,900
No there is only one pata drive in it.
Can you help on the 100% cpu usage?? Thats def making my pc run REALLY slow.
