Nothinman
- Sep 14, 2001
- 30,672
- 0
- 0
Nothinman - exactly - I would say more than that - most people are probably not even accessing the greater portion of their data , let alone the opsys . So , I am saying that , assuming the disk is close to full , if you access say , 5% of your data regularly , then if that 5% is totally defragmented chances are , you're not accessing much of the disk total area ( not sectors ) . But , if that same 5% will be fragmented , then there's a pretty good chance that you will access most of the disk area .
Same thing Modelworks - I'm not referring to what you describe - but the above - the average user may fill the disk - but only access a small 5 or 10 % - or even more if you like - but it'll still be far from 100 % . This may be , in fact a reason , why disks do fail , as people may be reusing the same areas all the time .
I still don't think the amount of wear on any one area of the disk would be enough to actually wear it out. At least on a mechanical disk, SSDs are a different story. Maybe, if you were constantly rewriting the same area of a disk for years at a time, but I don't think any normal user would have a usage pattern even close to that.
