specialk90
Hey Rob, why didn't you stop me earlier with the double posting. I feel like an idiot now since I didn't notice who I was talking to.
Ok, lets start with the 1 task, 100%, 4 tasks.... The way I see it, about 95% of the time, only 1 task is accessing the drives. For example in Photoshop, you are working on an image, the OS & page file don't need to access anything while the scratch disk can. I see about 5% of the time(not including virus scan) when the overall system speed might slow down to less than a single drive's max speed in Raid 10. However, for 95% of the time, Raid 10 is able to give you substantial speed & performance gains all the while protecting your data.
--"are you saying that you can take 4 disks , select 100 gb in Raid 0, then raid 10 on the rest???"
YES! This is why I LOVE Intel's Matrix Raid. No hardware raid controller that I've ever read about can do this.
--"Another question, are you using a hardware controler for this raid 10, from what i have read it is not recomendable to do raid 10 just by software."
Technically, this isn't software Raid since you are using the onboard Intel ICH10R which is part of the Southbridge. Over at Mac-land, they like software Raid for some reason. Software Raid 10 would be going into the OS with 2 sets of Raid 1 already created and "stripe" them by creating a Raid 0. This is not good for performance and reliability. One way for you to know that this isn't software Raid is because it is not created thru any software or OS.
However, Intel does provide a very handy program to install that allows you to monitor the drives within Windows as well as modify them. In the lower right of my screen, I have 2 little cylinders blinking at me non-stop due to the dead drive I still haven't replaced. Now, with my hardware Raid controller, I must log into its console to check the status of my drives.
Another important aspect is what if the raid controller dies or the motherboard dies. This question has me extremely worried as I have over 1TB on my 3ware Raid 5 (hardware) and if my controller dies, I will have to spend $350-550 for a controller to get my drives back up. On the other hand, if my motherboard dies(it has the ICH8R), I can get any motherboard with the same Southbridge or newer. So, I can get a motherboard with ICH8R/9R/10R/future 11R/!2R.... For you, you can get a ICH10R or future 11R/12R and so on and just plug them in and go to the first BIOS page and change it to Raid, and voila, its done. I have switched a Raid 10/Raid 0 setup between motherboards without any problem.
Hope this helps.
PS I should clarify something that was said earlier about Raid 10 read speeds: read speeds are not equal to a 4-drive Raid 0. They are slightly faster the a 2-drive Raid 0. Writes are certainly equal to a 2-drive Raid 0. For the specifics on Raid 1/10 read speeds, I will look into that so I can better explain it.
Hope this helps.
