- Dec 27, 2004
- 1,064
- 3
- 81
Originally posted by: Denithor
My recommendations:
Gigabyte G33M-S2L mATX $100
e4500 (2.2GHz, 2MB cache) $125
Antec Earthwatts 500W $55
Mushkin 2x1GB DDR2-800 $47 (after $10MIR)
Two alternatives:
e8400 (3.0GHz, 6MB cache) $200-220 (tight supply right now, price will fall as supply increases)
Mushkin 2x2GB DDR2-800 $88 (recommended if you plan to upgrade to x64 OS)
Since you don't plan to OC your CPU I would recommend getting one with at least 2MB cache (which will help to offset the lower stock speed). The e8400 will provide considerably higher performance but the cost is higher as well. Only consider the 2x2GB memory if you plan to use a 64-bit OS in the near future (32-bit OS will only register about 3.2GB of the memory). The Earthwatts powersupply is an excellent model at a great price with no rebates.
What are the differences in the board I posted and yours? (I am at work so trying to be incospicuous as possible lol)
I didn't realize the 8400s were at that price... and I was considering the E4500, but 6MB cache on the E8400 would suit me much better for my everyday computing
