For a heatsink, you want a 120x38mm fan, it's much more effective: http://www.svc.com/fba12g12l1bx.html . You could also go with the higher speed version and temperature control it (that's what I'd do): http://www.svc.com/fba12g12h1bx.html . For a case fan, can't beat curved-blade Yate Loons for ~$5.00 a pop: http://www.jab-tech.com/YATE-LOON-120x120x20mm-Case-Fan-D12SM-12C-Medium-Speed-pr-3826.html . Scythe, Noctua, and the rest are WAAAAAYYY overpriced for very little improvement and only at the high end of their operating range.
There are several designs of Yate Loon fans - the model with curved blades, which I believe I linked to, are the quietest with the highest CFM.not sure why they have so many different D12s, but I think the 33db/70CFM is the best blend of CFM and quietness.
Yate Loon D12SH-12 Curved blade from PTS - This is what Petras stocks mostly...it's a very good fan, especially for the price. Especially on the radiator. The 12V and 11V numbers are out-of-line with the expected and with what others experience and I can hear noticeable extraneous noise at those two voltages...probably something wrong with my fan specifically. I still like it too... Like most fans, it improved SLIGHTLY over its 0-hour test numbers.
Yate Loon D12SH-12 Straight blade from PTS - This is what Petras stocks occasionally...it's a very good fan, especially for the price. Especially on the radiator. Mine made no extraneous noises....it's SLIGHTLY better than the curved blade variant on the radiator, but SLIGHTLY worse in open air. I call it a draw overall. Like most fans, it improved SLIGHTLY over its 0-hour test numbers.
Yate Loon D12SH-12 Straight blade NOT from PTS - This is the D12SH-12 available from every place not named Petras Tech Shop. They DO use different suppliers and this fan IS different. It has different internals, scales differently with voltage and noticeably deteriorated from its 0-hour performance. It makes some noises I don't want my fans making: mainly light thuds and clicks. In fact, all but one non-PTS Yate Loon made extraneous noise. Oh, it also doesn't perform that well...look at the graphs.
Yate Loon D12SM-12 Curved blade from PTS - This is what Petras stocks mostly...it's a very good fan, especially for the price. Especially on the radiator. It's not as good as its ratings (56CFM vs. 70CFM rated) but overall the performance is very solid. Like most fans, it improved SLIGHTLY over its 0-hour test numbers. I really like this fan.
That's just FUD spread, innocently or otherwise. I've bought Yate Loons from Jab-tech years and have never had a problem -you buy the curved version, you get the curved version.BEWARE of any Yate Loon's not from Petra's Tech Shop
http://www.xtremesystems.org/forums/showthread.php?t=170224&highlight=yate+loon
Also - http://www.xtremesystems.org/forums/showpost.php?p=2641609&postcount=6 for direct comparison of the different yate loons.
I recall asking before, I don't recall if you responded. But how do you feel about the Gentle Typhoon vs the S-Flex SFF21F? The Gentle Typhoon is a double-ball bearing design spinning at 1850RPM to push 58 CFM at 28dba while the S-Flex SFF21F is a fluid bearing design (traditionally less noisy) spinning at 1600RPM to push 63.7CFM at 28dba.
I see you recommend the Gentle Typhoon, but since the price drop that happened on the S-Flex lineup ($15 instead of $20 on Newegg all the time now) making them the same price, I don't see why it would be wise to get the Gentle Typhoon (faster RPM which increase likelihood of turbulence) that pushes less air at the same sound level.
Thoughts?
OK guys..
NOTHING that comes in 25mm and i say NOTHING.. not even noctuna's (they actually suck horribly in all static charts), will beat the scythe GTs.
If you want something better, you need to step up to 38mm and get ultra kaze's or san aces.
And those arent quiet.
nice lil avatar there aigo, would that be sister #10032 🙂?
anyway, would DT be a worthwhile upgrade over yate loons for use with my xigmatek S1283? Thanks!
No worries, I'm aware for the Noctua's shortcoming. That's what I don't use them on heatsinks - using a bunch as case fans in an Antec P183 😉OK guys..
I dont like noctunas... i dont know why people keep recomending them when the reviews on there static performance sucked horrible.
Look at the GT's blades and compare them with the traditional S-Flex ones. They may be rated to push less air but they actually push more due to having better static pressure.
