Decarbonization using water..
Pacfanweb
13,155
59
It does work. I didn't watch the video, but you use a small vacuum line and suck the water into the engine gradually. Cleans very well.
Sabrewings
1,942
35
51
Yep, works well. I've done it. It's not as potent as something like Seafoam, but it's cheap/free depending on where you get it.
BUTCH1
20,433
1,769
Watch the vid, he uses a garden hose and BLASTS the intake!, it's LOLX10
leper84
989
29
86
So is this like when 4chan convinced people to microwave their Iphones? Because thats the vibe I'm getting from that video.
Ronstang
12,493
18
On carbureted cars I used to pour transmission fluid down the carb from a cup while holding the idle high , around 2000-2500 and when the smoke was gone do the same with water. I always did this right before a spark plug change. Sometimes I would just do the water in between spark plug changes. It really did clean the engines up inside of carbon buildup.
Reactions: Rob The Nailer
ronbo613
1,237
45
Yes, you can do that, it's like steam cleaning the inside of your engine. I prefer to spend $6 for a can of Seafoam or even a $4 knockoff Walmart version of it instead.
BUTCH1
20,433
1,769
Thing is, water is free and works just as well.
Yup, can you spot the cylinder (blown head gasket) that had coolant inside it?,
Pacfanweb
13,155
59
^Yep, it's the one that is nice and clean.
I've seen that many, many times....cars come in with a head gasket seeping into the cylinder, and whichever cylinders are getting the coolant are sparkly clean.
Steam is amazing.
ronbo613
1,237
45
Coolant is not water. Coolant/antifreeze can damage bearing material. You can use water to clean the inside of your engine, but if any water remains in the cylinders or other internal parts of the engine, it can cause serious damage. If you use a petroleum based cleaner like Seafoam, it's not an issue. The Seafoam-type cleaners do a better job dissolving the thicker deposits as well. If you can't afford $6 to clean the inside of your engine, maybe you should consider not doing it, or running a few tankfuls of premium gas.
Pacfanweb
13,155
59
What is a few tanks of premium going to do? All gas has detergents in it, and running premium with a little extra will make no difference.
Water isn't going to stay in the engine. You're going to suck it in with a SMALL vacuum hose, it's going to get compressed and turn to steam in the combustion process, and go out the exhaust pipe.
The coolant isn't what cleaned that cylinder in the picture. Straight water would have done the exact same thing. Seafoam isn't going to get it any cleaner than that pic.
ronbo613
1,237
45
Not going to argue with you, feel free to put all the water you want into your engine, a little extra will make no difference.
Pacfanweb
13,155
59
Running it through a vacuum hose isn't "a little extra". Sorry, but I've been in the car business for over 30 years, and I've done this, and seen it done dozens dozens of times. It works. Damn good.
I remember one old Ford 250 truck where at the tail pipe exit it had sort of a screen....I did this and it had hunks of carbon jingling behind the screen afterwards.
Re: the pic above: I had a hot rod that I ran straight water in the cooling system. Had a leaking head gasket. Pulled the head and 2 cylinders where the gasket was leaking looked like brand new. That was straight water, not coolant.
It works. That's a fact.
ronbo613
1,237
45
When I see the "been in the ____ business for thirty years" statement, I exit the conversation. Other people have been in the "car" business for a long time as well, maybe even me. Since it is you that determines what the "facts" are and everyone else is wrong, there is no point to discussion.
Since you are an automotive expert, I will leave this conversation with one final question; If running water through the engine keeps it so clean, why don't vehicle manufacturers install a water injection system as standard equipment to keep the engines running at peak performance?
Pacfanweb
13,155
59
Maybe because it affects power and the carbon buildup these days really doesn't hurt anything in the first place?
BUTCH1
20,433
1,769
Well I went ahead and did it, I used a spray-bottle on mist and wound up running about 20oz of distilled water through the intake. During the process I found my throttle-body opening near the butterfly to be EXTREMELY dirty so I sprayed some carb-cleaner on a clean rag and wiped the gunk all out. Following the treatment my hesitation during WOT is now gone as is the slight pinging I was experiencing. I had temporarily switched to 91 octane to avoid the pinging but now I can run regular again, it works!.
BUTCH1
20,433
1,769
It works, but in much less way than you think. The throttle body cleaning probably help much more.
https://www.youtube.com/watch?v=u6UeJXkzDW8
https://www.youtube.com/watch?v=t4vtYzezV7s
Yea, it's difficult to say which did more because that throttle-bore was WAY more nasty than I expected. I don't have a borescope but I see cheap one's on Amazon for $16-25 so I might grab one at that price. The back plugs are to much of a PITA but the front 3 cylinders are not bad to get at. Why I suspect the water worked was that a dirty throttle-body would not (I don't think) come into play at WOT and this is where my engine was having problems with intermittent missing, IMO carbon build up from my many short trips was the culprit. I used to drive 14 miles to work each way, now for the last3 years it's been 2.3 miles each way so the car is just barely getting out of open-loop when I pull into where I work. If I do it again I will get a cheap bore-scope so a before/after can be done on the front 3 cylinders. I'd also want to probe deeper into my intake manifold and see how that looks like.
Pacfanweb
13,155
59
A chemical like BG makes would probably work better in the intake or throttle body. When I was talking about the water cleaning, I'm talking about in the cylinder itself. There, the water is a good as anything. Steam. Not going to get steam in the air intake, so likely less effective.
Reactions: BUTCH1
Rob The Nailer
Ronstang, can you please reach out to me to discuss work on a "66 Mustang in Houston? Thank you.
