Originally posted by: zifn4b
Originally posted by: Fallengod
Good lookin out. Ive been wanting a few actually. I dont know if I want 20 though. Too bad these are dvd+dl. Id rather have dvd-dl
FYI - you are better off with DVD+R. The reason is because you can set the BookType to DVD thus making your burns have much better compatibility with standalone players. This is not possible with DVD-R due to limitations of the physical media. The BookType is usually settable by using hacked firmware and a BookType set utility for your burner. For example, on NEC drives, Liggy's firmwares are typically used.
BUMP for a good deal!
This is a great deal on verbatim's but they are NOT the only good DL's out there. I've had nearly no problems with Memorex DL's. The only times there were problems, it was because the source was bad.
Originally posted by: dealseaker
maybe next time, I will try them out.
Your personal experience notwithstanding, Verbatims are the only brand known to work reliably with the different burners and players out there.
I am not posting this to try to keep an argument going or justify a purchase, but to help make sure that others don't read your post and get the wrong idea. If you (or others) have tried other brands and they work for you, save the money and laugh all the way to the bank. For many others who need a DL disk that is most likely to produce a reliable burn, this is the way to go.
