*DEAD*Arctic Cooling Freezer Pro 64 $17.95+shipping (+maybe tax?)
joseraul
Credit to Castaa at SD:
Arctic Cooling Freezer Pro 64 for AMD Socket 754,939,940 heatsink with 92mm fan for $17.95 + shipping + tax (if applicable): Store Link
Checked out the store's rating and it seems good, though it's been some time since someone rates them: Reseller Ratings link
Searched and didn't come up with anything, so I believe it's not a repost.
I currently have a stock AMD cooler with heat pipes. I have lowered the RPM by a fan controller. I will let you know how the Freezer compares after I get it.
Appreciate it... when other folks use my computer they remark how quiet it is but it still seems loud to me... <sigh>
Cheers,
TJ
i have both too (stock amd with heatpipes and freezer 64)
the stock amd is louder at higher rpms
i run the freezer 64 at 100 percent fan and its silent over my psu fan
the performance is near identical as well for me...so i would assume this is better than stock amd heatsink but on par with stock amd heatsink with heatpipes
as for the seller, they are a local B&M for me as well and have been around for as long as i can remember, so they are definitely trustworthy
HOT DEAL!
Man...I just bought this from Central Computer on Monday for $29.99.
EDIT: Just called them, and there is no price protection. :thumbsdown:
From the description:
"Thermal Interface Material: Pre-applied MX-1 Paste"
Does this mean that you don't need any extra thermal grease? Also, would this be compatible with the Sempron 3100+ 754 pin?
Yes, Yes.
Originally posted by: Zap
I don't need this but... tempting. I'll bookmark it for now... thanks OP.
Last time they had the non-pro version for the same price, they were out of stock within a couple of days. This is a great deal, too bad I don't need one. Shipping rates are high for one, but better if you buy more.
dammed
If only these would turn 180 degrees, I'd be set
on my board ( asrock ), it blows either towards the back or the memory in the front
and my power supply ( super flower ) already has 4 fans taking out the heat
I wonder if I could put it in there and add some ductwork to the rear ???
Have to think about this.
I also have an Asrock 939 Dual SATA and I believe that you can rotate it and make it face any direction you want. That is why I ordered it!
Read the last paragraph on this page of the review.
