Damnit, I didn't pass Smog. Lil Help?
TechnoKid
5,575
Originally posted by: Pepsi90919
you said yourself the engine ran too cool, this can cause some issues. might want to replace the thermostat if you suspect it's faulty.
and i dunno why you wasted your money on the bosch platinums (actually, i must confess i've been there myself, but with the +4's), i think it came stock with NGK and it would probably work best with those.
I believe that the Bosch platinum+2 are oem spec'd for some toyotas.
Kelvrick, have you noticed a significant change in the gas milage of the car?
sillymofo
Banned
Aug 11, 2003
5,817
You can go to Santa Ana, there are places that will "pass" your car for a slightly higher fee than the regular smog check. You better know somebody though.
Kelvrick
18,422
Gas mileage has been around 24-25 but is recently 22-23. I guess thats pretty bad since I drive 65-75mph with 80% 65 on my way to work and generally don't rev above 3500 when I accelerate.
cr4zymofo: Yea, I could do that. I don't know anyone around here, but I do know people in Santa Ana (I used to live 15 minutes away from the area). I just don't know if I wanna drive 7 hours each way from where I amif there was some way for me to really fix the problem.
EDIT: Mine came with OEM NGK's though. They cost about the same as the Bosch's and the Bosch's looked shiny, so I went for it. :)
CrackRabbit
16,642
62
You can also put some Ethanol in your gastank, not a large amount mind you, should help lower the NOx levels
Kelvrick
18,422
One last bump for suggestions before I start my repairs and get it smogged this weekend.
I forgot to mention, carefully inspect the vacuum hose for leaks that leads to the EGR valve.
Squisher
21,204
66
When we used to have emission testing Michigan they allowed you to get plates as long as you spent $150 trying to pass the test.
Is there a similar policy with the California testing?
Pliablemoose
25,195
Just got 2 of my vehicles inspected, diesels are exempt from emission testing in Texas, cost a whopping $12 each for the stickers, VS ~$50 for a gas vehicle.
BTW, I'd do what Roger said, but also change the spark plugs, wires, distributor cap, rotor, change oil & O2 sensor.
EGR valves are pretty cheap, I'd just install a new one.
