DrMrLordX
- Apr 27, 2000
- 22,972
- 13,067
- 136
First of all, whether or not fans are difficult to install depends mostly on your case and, at least in my experience, what mounting mechanisms you choose to/are forced to use.
All of the cheap-arsed cases I've owned have pretty much forced me to use screws to mount my fans, though that may be more due to sloth/lack of imagination on my part. There are probably better things to use than screws in a standard fan mount. If you have cheap screws that strip out easily, fan installation is a nightmare. Otherwise it's a breeze even with screws.
As far as intake/exhaust goes, generally you use fans on the front of the case or on the side of the case for intake, while you use fans on the back and/or top for exhaust.
For helping to cool your CPU, there are many different case cooling strategies, though going heavy on exhaust can work (this can interfere with your PSU cooling itself in some cases if you take exhaust fans too far to the extreme). The best strategy is typically to balance intake with exhaust. In other words, try to make sure the total rated cfm of your exhaust fans is about the same as your intake fans. If you do that and negate cable clutter as best as you can, then you should be okay. Personally I like making sure that the net total cfm of my exhaust fans equals or exceeds that of the fan on my HSF, but that's just me.
Also, there used to be a nice cable management sticky in this forum, but I do not know where it has gone. Surely someone here can give you some advice on proper cable management in a CM690.
Finally, before we assume that it is case airflow that is a problem, perhaps you should tell us what intake and exhaust fans you are using now and what case/PSU temps you have as well (something like Speedfan can help you find that information).
