Hi All;
BACKGROUND
A few years ago, I built my house and installed cat5 runs in nearly every room... but all I did was the wiring going to/from a home run. Now, my family's growing up and they want me to get after it and get their PCs networked. Some want wired for gaming, some want wireless, some want to be able to do both. I'd like to be able to stream content to the tv's at some point in the future (wired or wireless). The network will start with 4 wired PCs, 2 wireless laptops (one's a Mac), and one wired printer... I expect it may grow some. The home's 2-story -- about 3700sf. Most of the neighbors have wifi. I don't mind spending $ for decent components.
ISSUE
I'm not really sure which components I should buy to get all this going, and you fellas seem to have quite a bit of knowledge concerning these things, so I'm hoping for some good feedback. Here's the questions:
- Exactly how would you set this up (e.g. go wireless and add a switch, get a router and add access points, or something else)?
- What components would you select (make/models)?
- Will I need a couple locations for wireless access points, or does one usually do it for a home?
- Broadband modem recommendation?
Thanks in advance for your time!
BACKGROUND
ISSUE
