Originally posted by: RichUK
Originally posted by: Zebo
Where and when did you get yours?
I am watercooled with huge 3x120 Black Ice Pro III (which BTW is on sale right now at DD for $44) LMK if you need any advice on water setup. I have a great case for sale too brand new cause I accidently ordered 2 by mistake. Lian Li where that rad can fit in top and has boat loads of room.
http://www.achetezfacile.com/lian-li-pc-73-slb-comparer-les-prix-117062.html
I can run 2800Mhz with 4200 but it's sh1tty stepping requireing lots of volts
i got mine from CPUcity.co.uk .. for some reason they had some and no where else did even in the US
😕 in fact they only had 2 a month ago and i nabbed one of them
yeah to hit 2.8 i need about ~1.6, but this chip gets quite hot at that voltage and speed, so water is the only way ..
I have a Coolermaster wavemaster .. i was looking to get the following:
Radiator:
DD Black ice Extreme II (2 x 120mm fan)
Pump:
DD D5 with 1/2 inch barbes
CPU Block :
DD s939 Copper TDX block
Chipset Block:
DD Maze 4
GPU Block:
DD nv6800
i am not sure what water reservoir to get though, and also what fans to use on the rad, also this will all be on a 1/2 inch hose setup.
ohh and not to mention a dremel to cut the top of my case for the Radiator, this is what has kept me lingering for a while, im not to keen on doing this but what they hey, why not ..
^^ what do you think of the above setup, ok? im looking to get a DFI expert when that comes out with a 7800, so all i will have to do is change the GPU block over.
ive never had one bit of experience with water so hopefully i have a smooth run on my first attempt, thanks if i have any queries ill pass them your way, thanks
