Hello All,
New System build (just a few days old):
gigabyte gaming 5 z170x mobo
i7-6700k
gtx 1070
16gb ddr4
when booting without an OC I get the healthy AO message on my motherboard led, but if I overclock the CPU even slightly I get a D4 message, which according to my mobo manual means "PCI resource allocation error. Out of Resources," so I guess it's weird that OC'ing the CPU causes the error, because D4 seems to be concerned with PCI cards.
From this thread:
https://pcpartpicker.com/forums/topic/42104-d4-and-d3-error
I got the idea that it might be the CPU OC, so I reset that and it fixed it. That is, I get the AO message when there is no CPU OC, but the D4 with even the slightest CPU OC. There is no GPU OC.
If I OC, then according to CPU-Z the speed of the CPU switches between the stock 4.0 and whatever I have set the OC to, whether it be 4.2 or 4.4 etc...would that happen normally?
There does not appear to be any stability or functionality issues so far, it's just the mobo light changes, but it worries me somewhat.
thanks
i7-6700k
gtx 1070
16gb ddr4
From this thread:
thanks
