spacejamz
I currently have the Corsair H70 hooked up to an i7-920 DO and have been thinking about switching to the Noctua NH-D14. From what I've "read", I should see a bit of a difference in cooling. On minor OCing (3.8ghz), I'm fairly happy with the H70 (low to mid 70's C). When I try to turn up the juice (4.2 ghz), the temps goes higher than I'm comfortable with (low to mid 80's C). Also, I'm a little worried that if the pump fails on the H70, I could do some damage to my system. The NH-D14 can cool with or without the fans. Your thoughts??
FWIW, from Noctua's website:
Is it possible to cool my CPU without a fan (passive) using Noctua coolers?
Noctua coolers weren't originally designed for passive operation although the cooling performance is sufficient in many cases. Unfortunately, it is impossible for us to indicate whether a certain CPU can or cannot be cooled without a fan, as this depends on various factors such as case temperature, case ventilation or the orientation of the socket. Generally, we recommend using a fan in the first instance and then lowering RPM while constantly monitoring the temperature.
How is the noise on the H70? I realize this is a subjective question, but I can hear my case fans now which was not the case with my 212+ and two coolermaster fans. This fact alone (and the $75 sale price from newegg) has made this upgrade worth it to me.
