CyberPower 425VA UPS $19.99 after $10 easy rebate
allisolm
Administrator
Jan 2, 2001
25,254
4,859
Staples will have the CyberPower 425VA 6-Outlet UPS for $19.99 after $10 easy rebate starting Sunday, Dec 7, 2008.
SKU 660428
230W/425VA
6 outlets (3 surge protected, 3 battery backup/surge protected)
Dataline (phone/modem/fax/DSL) protection
Page 16 (back page) of the 12/7/08 ad avaialble for viewing at staples.com.
Karaktu
Moderator Emeritus<br>Elite Member
Apr 24, 2002
17,752
10
Worth every penny and then some.
Throw away your $100 surge protector and replace it with this. :)
blueis300
249
Funnny the Best buy guy tried to sell me the $100 monster surge!!!!!
I bought my apc battery back up instead and had to explain things to the wife.
allisolm
Administrator
Jan 2, 2001
25,254
4,859
Just ordered this. Free shipping and one business day delivery and online submission of the rebate makes it all good.
VirtualLarry
56,578
10,215
Only 230W? Not good enough for a computer. What are you guys planning on using this for?
Kaido
Feb 14, 2004
50,992
6,907
Great for a router or a Tivo.
allisolm
Administrator
Jan 2, 2001
25,254
4,859
Exactly. TiVo. Our power tends, when it does have a problem, to go on and off several times in a few seconds and then the problem is over, but it's enough to make the TiVo start to reset. And TiVo starting from scratch can be a long process. Also my husband's desktop is less than 230W.
gorcorps
aka Brandon
Jul 18, 2004
30,739
454
Not everybody has a gaming PC, or a desktop for that matter.
Karaktu
Apr 24, 2002
17,752
10
Brown outs and blackouts. You only need a few seconds to shut down the computer. Battery backups are better than any surge-only device.
And, as I've said in another thread, your modern dual core PCs tend to draw less than 100 watts and idle closer to 65.
Limit of 10 per rebate, paid via a Visa check card.
Eric62
528
What's the Visa pre-paid card all about? They send you a Visa card with a $10 credit limit???
dguy6789
8,558
Would this be good for plugging my router, my pc, and my monitor into? I don't need it to run on battery alone for any extended period of time, just enough to handle power flickering off and on on occasion.
dman
9,110
Depends on the amount of power your PC uses, if it's an off-the-shelf system (Dell, HP, etc) then it'll probably work OK for said purposes. If you have a CRT instead of an LCD it'd likely be pretty limited run-time, but even then would probably still work.
For another $20 or so you can usually find one with slightly more power and likely a USB connection for XP/VISTA to monitor and auto-shutdown if power gets too low. For example, Costco's has had a refurb'd 550VA APC unit for sale @ $39.95 OTD.
Throckmorton
16,829
You could plug your computer and router into it, but maybe not the monitor. Then again, it may be fine with even a big LCD.
I bought two. I might go and buy another one for an Xmas present for somebody
dguy6789
8,558
My computer is in my signature, I built it myself.
This is my monitor: http://www.newegg.com/Product/...x?Item=N82E16824005112
I don't really need to it to run for more than 60 seconds on battery at all.(Probably not even half that) The power in my house just somewhat flickers sometimes(lights dim and stuff) and it causes my router to shut off and turn back on on occasion.(Main reason I want this is for the router) I just figure I might as well plug my pc into it too.
How does the ups the thread is about compare to this one?
http://www.newegg.com/Product/...16812106005&Tpk=le1200
I have read that the cheap UPS do not protect the pc from voltage fluctuation. Can anyone clarify any of this for me? I know next to nothing about these things. The one I buy will be my first one.
Kaido
Feb 14, 2004
50,992
6,907
Yup my Quad with 8 gigs and an 8800gtx draws a hair less than 200w at idle, so for blips it'd be just fine if you're on a budget.
Throckmorton
16,829
Might want to buy one UPS for the computer, and one for the monitor and router.
Blain
Is the CyberPower UPS line interactive?
Old Hippie
6,361
Not this one. You need to be looking for the "AVR" (automatic voltage regulation) units for that feature.
Throckmorton
16,829
Really? Argh!
jrichrds
My overclocked E7200 system consumes less than 40W from the wall at idle and less than 90W at load. I currently have it on a 350VA/200W UPS.
khurios2000
7,531
my E8400 overclocked to 4.25Ghz + 9800GX2 overclocked 700/1750/100 running dual GPU2 folding@home only cunsumes 140W according to kill-a-watt
CybrGuy
10
Just ordered 5 used a 30$/150 coupon and added a 59cent pack of paper clips. Total price per unit was 15.60 after rebate.
CybrGuy
10
Kill-A-Watts are cool aren't they!
Just keep in mind it will draw a lot more when not idle. A few people have posted that their 9800gx2s use about 180 watts at peak. Load up a game and check your power usage then. My guess is that your power will go up to about 300W when running a game.
