cutting case problem with dremel
vsong
225
well, i started to cut my case with a dremel tool and well its not looking so hot. i tryed to cut a design but now i have messed up to much that i now have t cut a sqaure. the edges are bad and what not. any other tool or suggestions. the case is steal.
Spoooon
11,563
203
Try using a jig saw. You can use the dremel to clean up the edges and try to make it even after cutting the square out.
edit: Go slowly. You're supposed to let the saw do the cutting.
0roo0roo
64,795
84
there are grinding bits to finish the edges. you didn't have the dremil on fast enough? you push too hard? you shouldn't . aluminum cuts much better anyhow.
whats a design? you weren't trying to cut a blowhole?
radioouman
8,632
Dremels are tough to control. A jigsaw is better to cut with unless you have something to trace for the Dremel.
vsong
225
i have a variable speed dremel. im cutting really slow. actually making an engraving first so i somewhat have a guide to follow.
lozina
11,711
8
Are you using an armored HumVee for a case? I had no problems... go slow and cut out your shape then finish edges with grinder bit
alkemyst
83,769
19
Probably be better to have the dremel at full speed for carving stuff and the right bit. You want to let the tool do the work though.
It's hard to control a dremel without using a foot switch and flexshaft for intricate work.
