- Jul 20, 2001
- 73,775
- 35,640
- 136
You're not using enough butter.
Too much butter is very bad for you.
When you get my age you have to watch these things. :'(
Problem is the process is ablative so you have the darkest toasted edge imaginable. Would you eat a piece of bread that was used as a heat shield on a spacecraft? D:
If you want to cut it with laser precision without ablation a 50k psig jet cutter will do wonders.
Watch them cut food with a laser. Little to no excess burning.
Bread http://www.youtube.com/watch?v=Hqp4M4xEmXQ
Pizza http://www.youtube.com/watch?v=ej3KSfVU5aw
Engraved apple http://www.youtube.com/watch?v=OVmOSBydEOc
Table saw would be the best bet, adjust it so the blade is half it's thickness from the side bar, pass the bagel through vertically, rotating it once it's in the blade. Sounds unsafe though.
You could place two heavy objects to hold it vertical and cut it with a mitre saw too. Use the finest tooth blade you've got. If you go slow enough, it will even toast it for you.
That's not a safe way to use a table saw! NEVER allow the stock to move with the blade or prepare to get it tossed. Granted a bagel is soft compared to oak. A ten inch blade all the way out should afford decent depth to cut an average bagel. Just don't use your hand to keep it pressed against the rip fence. A good blade will cut very clean instantly. A blade in poor shape may pull a bit and tear. If you hog in and it grabs let go, it's food for the dust collector vac!![]()
I'm going to bet that in a bread bakery, where they make the sliced bread, the bread slicing mechanism is far more similar to a bandsaw than a lathe.
Been a long time since I was in the Strohmann's plant, but I don't think it was like a guillotine at all. More like a bunch of parallel blades acting like scroll saws.Guillotine would be the closest.
But sliced bread can be, which is what DrPizza was talking about.Bagels aren't soft.![]()
A 1kw laser would also work, it has no "drag" so it will make a nice perfect cut, and leave a nicely toasted surface.
Honestly I would stick with my original recommendation of using a coping saw blade after wiping it down with 99% IPA.
We were debating the best way to cut a bagel in absense of your 'typical' utensils since we have a small shop but apparently no knives in the kitchenette
