- Jun 20, 2014
- 61
- 0
- 0
If you have not bought your PC case yet I would seriously look at the Phanteks Ethoo for @$240 or if you can swing it the Corsair 900D at @$320.
Yes it is already bought, and HD cage removed! I looked at both of those, and the Phanteks looked to be just as big, if not, maybe a tiny bit smaller. The 900D would have been nice, but I am not paying $300+ for a case.
Here is what I have to work with now that the HD cage is removed (Had to drill out 20 rivets!!!):
Sorry for the crude drawings, but that's the best I can do haha. The only measurement that might be confusing is the one at the bottom of the case where it is labeled 6.5" (useable space). That is the width of the bottom of the case.
So, I know I can fit a 480 at the top, barely. As for the bottom, it looks like I could get a Monsta 360, or maybe even fit a couple 240's. I think I would have room for two 60mm 240's, or even two Monsta 240's depending on the how I would have to mount fans if putting two RAD's right next to each other. Hell, I could probably stack two 60mm 360's on top of each other if such a thing is possible.
EDIT: I think I have two options regarding my lower radiators. Either a slim 360 and 240(which will barely fit), or two Monsta 240's. I think I will end up going with two Monsta 240's because those won't choke the case and be spitting the exhausts directly into each other. I don't see any reason why those won't be enough for my needs.
