I have the strangest probs with the CUSL2. When I first put together the system:
AOpen maxi tower 300W
CUSL2
PIII 733MHz
256Kb PC133 memory
SB Live
IBM 30.7 GB ATA100
Plextor CDRW
Pioneer DVD
USB optical mouse Logitech
the BIOS showed the CPU temp to be 80 Celsius! The processor did not seem to be running hot so after some fruitless trials I took the mobo back to the shop. They put a brand new mobo and tested it without actually installing it and the temperature readings were OK. Then they inserted the mobo and tightened the screws and the temperature readings were back at 80. They're now trying to solve the problem, but that seems mighty strange, as if the stress of tightening the screws had caused some bad contact? Anybody heard of anything similar?
CUSL2
PIII 733MHz
256Kb PC133 memory
SB Live
IBM 30.7 GB ATA100
Plextor CDRW
Pioneer DVD
