When i'm playing cs:s my crosshair gets *lost* in bright areas or when i go from a dark area -> bright area in dust 2. how do i go about fixing this? does it have to do with the crosshair being translucent? how do i make it not?
This. I like green.Isn't there a setting in the options to change the color?
back when i was a hardcore FPS player i used a laser pointer fixed on the center of the crosshairs on the screen. I fixed it over my shoulder on a shelf behind/above me. This also gave you a aim point for those weapons like sniper rifles and shotguns that dont give you a crosshair at all in some games unless you are zoomed in or using iron sites. It made a huge differnce being able to one shot people with a sniper rifle up close cause you were dead accurate even when not zoomed in on the scope. Im to old for that crap now though![]()
lol Clear tape + Marker = better alternative. This was on my Glass Screen CRT though![]()
Wtf? Seriously? LOLI wore glasses with dots on both lenses so that when my eyes aligned them, they would form a single dot in the center of the screen. of course I had to stay perfectly still
just have crosshairs burnt into the center of your retinas. noobs.
Doesn't bother me. I just use a piece that's about the same size as the crosshair, so you don't really notice it when you're playing. It's kind of in the way when web browsing, but nothing terrible.Anyone figured out a good way to put a crosshair on your screen for LCD screens? I've tried scotch tape + marker, but never works well, always cloudy and throws my vision off.
