CS:S Advanced Tips
M0oG0oGaiPan
7,858
digitalgamedeals.com
Originally posted by: AnMig
I also did not know the momentary increase in accuracy when changing direction while straffing or when pressing the both left and right straff keys together.
does this trick only work with the AWP and Scout? I never use the sniper rifles since I suck at them.
There's a move you can do with the rifles it's based on this same principle. They call it the stop strafe. Lets say you're in a long distance fire fight. You would strafe right and then touch the left strafe button and then for that split second you're accuracy goes up and you fire a 2 - 3 round burst. You would then strafe to the right again and repeat. Or you could mix it up.
Also if you happen to be scouting you actually run faster while holding the scout than you would while holding the knife out.
KeithTalent
Administrator
Nov 30, 2005
50,231
117
Originally posted by: thescreensavers
the new update sucks and now half the servers don't work good
:confused: what does that mean exactly? How do they not "work good"? I was on last night for a solid hour and did not have any unusual problems.
