Originally posted by: Zebo
Originally posted by: stevty2889
34,698
Case in point. These overclocked San deigos at 2800Mhz will destory a 3.8 Prescott in every real world bench there is. Not here, Not with synthetics. They loose by over 10%!!
34,698
Yeah, it definately rewards HT! Is there anything that proves HT has a real world performance advantage? I,m not even sure what kind of apps are optimized for HT?
Originally posted by: Shimmishim
mine
34,044
ALU = 10351
FPU = 12771
MEM = 10922
Clawhammer 3500+ @ 2.81 ghz
OCZ VX pc3200 @ 1.5-2-2-6 1:1 running 256 HTT
not bad for .13 tech chip![]()
Nice score Shim! I think this really shows that this program loves memory bandwidth.
Your score beats my SD3700+ by 1400 points, even though I was running 2860mhz (50mhz higher).
But your ram at 256mhz 1.5-2-2-6 clobbers my ram at 236 2-3-2-7, this shows up in the MEM score as well as the FPU score.
The more scores I see, the more I realize this program is heavily biased towards Intel. It heavily rewards HT which AMD's don't have, and it heavily rewards memory bandwidth, which has been proven to have little performance affect on A64's. And it seems to place very little value on highend graphics cards, so if your primary performance requirements are gaming and normal single threaded apps this benchmark is worthless.
Originally posted by: Verna
Well, not really good, but then it's untouched, 18669 were my score.
Stock 3000+ Venice.
I am like a piece of iron nowOriginally posted by: Zebo
Max - My ram is 1GB Ballistix @ 241 Mhz 2.5-2-2-7 1T
Hey DP you're gonna double that score in two weekshowz the manual labor?
The Operations Support Building II at Kennedy Space Center is designed to exceed EO13123 and 10 CFR 435 energy efficiency requirements and will use at least 47 percent less energy than the temporary, modular offices it will replace. The project will incorporate an automatic irrigation system, 100 percent native plants with low water requirements, high efficiency lighting with occupancy sensors anddaylight-compensating dimmer controls, variable air volume HVAC systems with variable frequencydrives on air handlers and chilled water pumps, and advanced filtration to maintain adequate indoor air quality
Originally posted by: MADMAX23
Please, tell me your Ram timings and speed!
