Crystal Power supply
GprophetB
2,632
link
Anyone have exp with crystal power supplies?
Thinking about picking this up to power a
Athlon xp 1800
4 drives total (2 HDDs, 2 optical)
9800xt
Pair of UV lights
6 80mm Fans
Fan controller
External case lights
EDIT: CORRECTION this is made by LOGISYS (i thought crystal was the main brand/manufacturer)
GprophetB
2,632
Wow, looks like i got my own answer! This thing performs like a champ and besides the semi crappy sleeving job looks great.
aatf510
1,811
A $80 PSU with 16A @ +12V? Definately not worth the money. Plus I have heard enough horror stories with Ultra PSU.
Also, a xp1800 might bottleneck you 9800xt.
GprophetB
2,632
yeah i realize, ill probably be in the market for a barton2500 that i can slam to 3200 speeds.
we will see though
So the crystal may be a good buy then?
EDIT: sweeeeet rig btw taottrett
Oyeve
22,078
888
Regarding PSUs, I have noticed several things.
Most "enthusist" PSU are really way over priced. I have used Antec, A-open and other "Highend" PSUs in my day and have used no name brands like Wintec, I currently use one in one of my systems for 3 years straight, many devices, never had an issue with the Wintec 450w.
I recently purchased an Aspire Concord 500w PSU for 59 bucks, and you know what? Compared to my very expensive (150 buck) Antec, the Aspire blows it way. This thing is solid black alluminum, has enough connectors to power my 6 HDs, Vid card, DVD Burner, CDRW/DVD drive, CPU fan, 3 case fans, Diskette drive and I still have a one SATA and 2 Diskette drive connectors left over without using any Y connectors, and upon looking in the chassis, which has 2 fans and even gives you a free case fan and controller for 4 more fans, I notice it has 2 excellent looking heatsinks inside. So with all my crap attached I ran monitoring tests and this thing rocks. I am never spending big $$$ on an overratted PSU again! :)
GprophetB
2,632
wow, can you link me to where you bought yours? Are the cables UV sensitive at all?
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
$49 for a 500W power supply made of Acrylic?
I'm scared. Seriously. SCARY.
I've got the Ultra myself and when I worked PC retail, we had about a 1% RMA rate. That 16A on the 12V rating is wrong, though. Well... Not wrong. Just not fairly presented. MOST power supplies give you their peak rating on a rail. Like when Antec tells you that the NeoPower does 18A and 15A on the 12V, that's Max load, not continuous. That 16A is the continuous. The Ultra X-Connect actually does 34A on the 12V rail (unless you have the Euro model. Then it's 28A or something like that.) Check the spec with Ultra's website or one of the many reviews.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Hmm.. Too bad that review didn't take better pictures or took apart the acrylic shell. I'm curious to whom really makes it.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
I don't know man... It's $50! I've yet to see any decent 500W power supply for only $50. Never mind one that's made of acrylic and has two LED fans.
I'm half tempted to buy one just to take it apart! :)
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
WHEW! Took this long, but I FINALLY found a vendor that had the damn rail specs!
From: http://www.geeks.com/details.asp?invtid=PS500AC
# +3.3 V, 28 A
# +5 V, 34 A
# +12 V, 14 A
# -12 V, 0.8 A
# -5 V, 0.5 A
# +5 Vsb, 2 A
That's less amperage available on it's ONLY rail than most dual rail 500W power supplies have on EITHER of their two rails. I'll pass.
KamiXkaze
177
yep same here I have a antec in one and the other one came with a generic brand and so far the generic has been holding up.
KxK
GprophetB
2,632
hmmmmm, well crap i dont wanna drop 50 on a powersupply and have it die, and i sure dont want to spend more than 50 bucks
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Actually, Acer and AOpen power supplies are very well made. Yeah, they're not flashy... but very stable.
We built about 20 small servers with AOpen 350W power supplies and they've run 24/7 without a hitch.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Probably the best < $50 I spent on a power supply was the TTGI/Topower/SuperFlower 520W. It has 18A on the 12V and comes in four colors. As long as you don't have an SLI video card and a Pentium 4 together on the same motherboard, you should be fine. ;)
Patrick Wolf
2,443
My recommendation goes to Ultra X-Connect
Pics of mine.
Reduce Case Clutter. - I *might* add wire ties later.
Not Bad For $109 - Blue shines out back of the case too, pretty cool.
I should also mention this is the first PSU I've ever bought. My older one was a Chieftec 340W, some stupid thing Alienware put in my PC when I got it 2+ years ago.
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
He didn't want to spend $109, though. $50 is the "target price." ;)
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Originally posted by: GprophetB
That original link i put up said this thing is solid, and yes 50$ target.
I'm not putting down the reviewer or the review site. That original link is a site consistent with reviewing case mods, not torture testing power supplies. The test rig specs were never listed and there's no mention of any kind of load testing.
I've got an Antec PP300V that'll power an Athlon XP 2800+ with 512MB of RAM and an FX5200 if that's all you want. It's probably not any worse than that Crystal. ;) $20 shipped and it's yours! :)
GprophetB
2,632
nah i think ill get an X-connect actually, doing some more reading and this seems like the way to go
i hate spending that much but the modular cables are a big time strong point (and that crystal only has 4 stock molex connectors) (* i know i know theres splitters to get but id rather get a modular PS anyways)
Ill post pics in a few weeks when the build comes together
