A bunch of enthusiasts that post in a thread proves that they're made by Leadman? NONE of those people making the claim I'm sure either own or have even seen or held an X-Connect. Open one up and it has a Wintech part number right on the PCB. Run the UL listing number and it's listed as manufacturered by Wintech. Open a Leadman and you've got something that looks COMPLETELY different that I believe isn't even UL listed! I don't even think Leadman makes Leadman anymore. I think they've been reduced to just a reseller (it's a tough market out there.)
Because someone sells something under their own brand and they've been known to make similar products in the past means that they make the other product as well? That's some funked up logic there, Zepper. Did you ever see my Grundig radio in Nexxtech packaging analogy in the other thread that mentioned X-Connect that you crapped on? Or did you refrain from responding because you know I'm right? :Q
Look. Here's an example: I hate Abit. Absolutely loathe them. And I'll post that from time to time and give my reasons based on my personally owning them and having sold them and servicing them, which is fair for you to do with power supplies since you're a vendor yourself. But when you say, "I hate Ultra" based on nothing more than what other people say or based on where they're being sold out of, you're ccompletely dis-crediting yourself. I don't go around saying "I heard Abit boards are made by PC Chips," whether it's true or not, just to solidify my point. If someone wants to argue with me that Abit must be a good board because they've got one and it's rock solid and whatever, then fine. I back down. You've going around to every forum you can find and crapping on Ultra's product based on NOTHING but rumors backed by no investigation or personal experience.
I don't know anything about Crystal power supplies except for it only has a 14A rating on the 12V rail and it's very light in weight (ligher ship weight than any other power supply from the vendors that have them and isn't acrylic heavier than the steel they use to house power supplies?) Those are the FACTS and the only FACTS I know. I don't know who makes them or what their RMA rate is. But if someone that OWNS a Crystal can tell me that they've been able to pull 168W off the 12V of a Crystal power supply and the 12V rail never waivered from 5% of 12V in either direction, I'd go ahead and say, "Wow. Not bad." and leave it at that.
And yes, a lot of Acer's power supplies are made by Fotron. They often don't even come up with their own model numbers and use Fortron's, but even the AOpens that aren't made by Fortron have been good to me. By weight alone the 300W that comes in their QF50 case is heavier than half the 500W's on the market and that unit's not made by Fortron (thank God, because if it did, it'd be a lot more expensive too!)
