Originally posted by: bigsnyder
Only get 60-80fps? Whats wrong with that?
Originally posted by: cyrusm
i think the difference between c2d > c2q will be dramatic. nothing less can be expected since its been confirmed it takes full advantage of quad cores as well as duals.
as for the rest, i think youre all overspeculating. this is half life 2 all over again. so much hype, eventually a billion articles about "will your pc run it?" "get your pc HL2 ready!". then it turned out you needed only a mediocre system.
c2d, 8800 any version, 2 gigs of ram --->>IMO<<---- will run it just fine, and if you have anything better, then it'll run even better.
Take full advantage of dual and quad cores? Sure, at a low res. Do you really think there will be a noticeable difference at 1600x1200+ in frames? I doubt it.
As Matt2 said, just fine is hugely defendent on the person. To some, 25fps at 1280x1024is just fine. To me, thats not even close to playable. Like Matt2, Im at 1920x1200, have been for three years. I dont think there will be a system out there that will run it at high settings for at that res. I think this game will put the hammer on all systems, just as Farcry did, and still does with todays systems at a high res. Foliage is a killer. Many games show this.
Originally posted by: Cheex
I, in all honesty, would rather to play a crappy game with superb graphics, than a superb game with crappy graphics...:sun:
If the Acer 24" can do 1:1 pixel mapping I'd still go with that. Even if you can't run 1920x1200, you can turn off flat panel scaling and run 1680x1050 which will run the game with bars on all sides. Viewable size will be a bit smaller than a 22", but at least you'll have the option of running 1920 in current games. For most games, an Ultra at 1650 is going to be wasted potential.Originally posted by: btdvox
What you guys think? Reason I ask is because I bought a new 22" LCD for 282.00 (Benq 222WH) and while its a great monitor and looks awesome, I found a ACER 24" Lcd for 485.00- i dont know if i should spend 200 bucks more to get a higher res, but If I cant run everything at Max using crysis, i might as well stick with the 22"
Id rather run at 1650X1080 at max settings with some AA than at 1920 at some settings lesser and no aa.
And also I have a new Samsung LED DLP 56" which is 1080p so i plan on playing the game on that sometimes. Any advice?
Originally posted by: idiotekniQues
quad core at 3.3, 4 gigs of ram and an 8800gts (only 320mb) are eagerly awaiting this game.
not so sure about this nanosuit as i would prefer more realistic gameplay but i am psyched! as said above, great graphics will not save a bad game, like doom3.
Originally posted by: Noema
Well, technically they can do 1:1. They've been broken for months, though some people report it now works with the new 16*.* patches.
1:1 doesn't work for me with FW163.11 on my 8800GTS Vista 64-bit.
